They denegrate the Honda so they feel better about their own decision to purchase.
That is a very accurate and perceptive statement.
Sheeple
And that is a very accurate and perceptive descriptor !
Part of the price of admission to ALL these new thumpers that spin well over 10,000 rpm is that they
all will need new valves and head work after awhile. Duh !
It's not like Honda is the only brand that'll eventually need it , instead it's starting to look like Honda's need it maybe a little
less than some of their competitors.
The Yamahas probably will go a little longer, but then the cost to rebuild a Yamaha leads like statements like this from Dirt Rider regarding Yamaha rebuilds: "The owner then must decide whether to put more money into the rebuild than the bike is worth". Hmmmm.
Honda rebuilds are very reasonable,top end,bottom end or both.
I always refer doubters to that Dirt Rider 200 hour tear down for a 450X that had the crap ridden and raced out of it. ONE exhaust valve needed adjusted,ONE in 200hrs. The piston,bottom end,transmission,the valves, all A-1.
There is also a whole lot of valve checking and shimming going on to bikes that don't need it, because the timing marks aren't set correctly, the feeler gauge isn't going in at exactly 90 degrees or the tension on it is wrong, then the owner starts ordering and replacing shims for no reason at all.
This is an elephant in the room nobody want's to talk about. How can Dirt Bike run a 24 hour on a stock bike right out of the crate and at the end the valves are perfect ? How can Dirt Rider get all those hard hours out of their's, all these owners here with that many hours or more and have no problem, then somebody has 5-10 hours (or less !) on their bikes and they think they have screwed up clearances ?! And their bike is running fine ? I believe a whole lot more owners are screwing up their valve checks than I believe Honda gets sloppy with setting the clearances during assembly.
If your UniCam Honda starts easily and runs great, leave the valves alone. They need clean,properly seated air filters,clean oil and a bath,and will reward you with many ,many long hours of excellent ,dependable service. Doug
