EXCESSIVE CHAIN SLAP
  • ocliff4
    by ocliff4 » Mon Jan 01, 2007 11:00 am
    I HAVE A 2006 450X,AND THE CHAIN SLAP AT THE COUNTER SHAFT SPROCKET IS DRIVING ME NUTS!!!,
    I CAN REDUCE THIS BY OVERADJUSTING THE CHAIN
    BUT I RUN THE RISK OF BREAKING THE CHAIN OR
    DAMAGING THE SPROCKETS.DO I HAVE TO SPEND BIG $$$$$$ ON A CHAIN GUIDE AND WILL THAT FIX THIS
    PROBLEM????PLEASE LET ME KNOW IF YOU HAVE ANY
    TIPS!!!!!
  • mharry860
    Chain slap
    by mharry860 » Tue Jan 02, 2007 7:14 pm
    My understanding is that the problem isn't the slap itself, but the way the swingarm magnifies the sound. Replacing the chain guide with a TM Designworks guide helps , because it's attached with double sided foam tape, which insulates it from the swingarm. I just loosened up the stock one and layed down a big layer of silicone caulk, I let it dry for a while then reattached the guide. Beware 100% silicone is a you know what too clean up, get clear or grey so it's not so obvious.
  • tkrrox
    by tkrrox » Wed Jan 03, 2007 11:05 pm
    my tm with the foam tape is at least 2x as loud as stock...
    ...i hit stuff...
    rocks,trees,cactus...i don't play favorites
  • mharry860
    by mharry860 » Thu Jan 04, 2007 10:25 pm
    Hhhmmm, guess I shouldn't believe everything I read. I do believe my silicone solution helped, but then again, I've also been trying not to lug it so much.
