TRX125 carb help
Posted: Thu Nov 01, 2007 11:40 am
by Drew
Guy's, I've rebuilt the carb on an 85 TRX125 because the needle would no longer stop incoming fuel and it's still doing it. I cleaned the seat in the casting really well and it looks like it should seal off but it won't. Any suggestions? Thanks
Posted: Sun Nov 04, 2007 2:08 am
by Canuck
Did you change the needle and seat? If that has been changed, I would also check the float level as well. A good ball park would be a level float to the body if it is a standard type needle.
Posted: Sun Nov 04, 2007 3:51 am
by zak13
do you have a clip on the needle if so what position is it in
Posted: Sun Nov 04, 2007 2:57 pm
by Drew
Yes, I put a new float and needle, but I didn't get a new seat. It seats in the casting. And, I put a new throttle needle in it at the same clip position that it was at (third groove). Any ideas?
Posted: Thu Nov 08, 2007 12:38 pm
by Canuck
Make sure your float level is correct, the carb can flood if the float level is too high. You may also have problem with the cast in style seat, it may be marked up or have scratches in it or just plain worn....if thats the case, you will more than likely need another carb.
