Crf250r 2004 versions
  • Gurfin888
    by Gurfin888 » Wed Sep 22, 2021 4:59 am
    Hello everyone! I was going to order some parts from partzilla to my crf250r from 2004. But I noticed that there were an A version and an A-A version. What is the difference and how do I know which one I have? I live in Sweden if thats any help. Partzilla adviced me to check with a dealership what version I have using my VIN. But they didn’t even know what the A and A-A version was. Thanks in advance!
    Re: Crf250r 2004 versions
    by JimDirt » Wed Sep 22, 2021 9:11 am
    As far as I know , it is when parts are superseded , in other words , either the part # was changed on some parts , or they made a change to the part that reflects the next year model which may have a better design , but the part should fit either .... there is no real bolt on or functionality issues using either .... but generally , I just choose parts from the first one (single A) , but there should be a asterisk ( * ) on the part # and below the list it should give a explanation as to the change if any ..
    Example:
    I highlighted in yellow the part with the *
    Explanation highlighted
    Hope that helped ;)
  • Gurfin888
    by Gurfin888 » Wed Sep 22, 2021 11:22 am
    Thank you this helped! I cant seem to find any * on partzilla tho.
    by JimDirt » Wed Sep 22, 2021 3:51 pm
    It will be on the OEM Parts Fiche ... so not sure what Partzilla is using , but most all retailers or distributors use the OEM fiche
    Here is the A:
    https://partsfinder.onlinemicrofiche.co ... 250R-A4-A)
    Here is the A/A:
    https://partsfinder.onlinemicrofiche.co ... 0R-A4-A/A)
    As my example above in the prior post shows for the Crankcase Cover , there is a asterisk , also in several other places depending on the particular parts page you are looking at
