2022 crf250r Wheels
  • RC14
    2022 crf250r Wheels
    by RC14 » Wed Sep 01, 2021 12:22 pm
    I am just wondering if my spare wheels for my 2019 crf250r will fit on the 2022. Plan on selling my 2019 but not sure if i can use the wheels or not. any one know.?
    Re: 2022 crf250r Wheels
    by JimDirt » Wed Sep 01, 2021 2:11 pm
    They should be the same , as long as the rear hub width from rotor to sprocket is the same , they should fit , I have a 20 450R and I am using my old wheels from my 02 450R with a 3.75mm spacer for the sprocket as a spare set , as that is the only difference from earlier years to later is they moved the sprocket over 3.75mm , so a spacer takes up that space and does not compromise anything , the physical hub part where the bearings are should be the same from 04 on , at least on the 450 , aside from the front rotor size as the earlier years were 240mm front rotor and now are 270mm , but that should be the same in your case
    So front should fit no issues and if the rear is the same width between those 2 points then it should as well , so the 250 should fit from 16-21 , or from 04-21 for the front and depending on if they changed the rear hub like they did on the 16-21 450 ..... Hopefully that makes sense ... ;) 8-[
  • Sonmar
    by Sonmar » Sat Sep 04, 2021 9:49 am
    Have you sold your 2019 yet? Do you have any spare motor parts for the 2019?
