engine hunting of idle
Posted: Mon Apr 03, 2017 6:13 am
by scottscrf250
i noticed with my bike the engine hunts as you hold the throtle just of idle or are just acceleration slow of idle sounds like a lumpy cam
anyone have any idea how to smooth it out
Re: engine hunting of idle
Posted: Tue Apr 04, 2017 12:25 am
Is your idLe jet and fuel screw dialled in give even running. Sounds like running rich off idle.Try turning the fuel screw in a quarter of a turn. I assume the choke is fully off. See how that goes and let us know. The aircleaner is clean,not over oiled or water logged. Did it run ok previously?
Posted: Wed Apr 05, 2017 6:24 am
If it is not a jetting issue as Aussie described for you - It could be an air leak ? That description fits the air leak characteristics. Just a thought for you.
Posted: Wed Apr 05, 2017 6:49 am
by scottscrf250
thanks for the feed back what i proberly should have also said thats its a 2014 running fuel injection,maybe i should find some specs on the throttle position sensor set up.
Posted: Wed Apr 05, 2017 8:00 am
Well - that does change things. Maybe still look for an air leak but other than that I'm out of my "old" school trouble shooting. I'm an old carb guy on all my bikes...and I like it that way.
