RUNNING A LED HEAD LAMP ON A CRF250R
  • scottscrf250
    by scottscrf250 » Mon Oct 10, 2016 7:28 am
    8) 2014 crf250r hi i want to know if any one has fitted a twin led lamp to the front of the bike and run it from the stock magnito coil
    by Aussiecrf230 » Wed Oct 12, 2016 3:01 am
    What is the total wattage of the two LEDs?
    LEDs will need a DC output. Does the R have a DC rectifier?
  • scottscrf250
    by scottscrf250 » Thu Oct 13, 2016 6:53 am
    it has a rectifier that runs the fuel pump but i think its 6 volt
    the led is 22w
    by Aussiecrf230 » Fri Oct 14, 2016 5:35 am
    What does your manual say is the output from the stator. Check wiring diagram the R use to feed directly from Stator to Ignition Control Module. Do they still do this? With 22 watts that is near enough to 2 amps. I am guessing you will need another winding and some rectification to supply LEDs.
