05 250 decomp
  • 250rJoe
    05 250 decomp
    by 250rJoe » Mon Aug 29, 2016 7:33 am
    Hey guys I have an 05 crf250r I just put a fresh piston and rings in it with my cousin who has many years rebuilding motors, we think the auto decompression valve is faulty because we cant get it to start and its kind of easy to kick over any help is really appreciated thanks
    by Back2-2 » Mon Aug 29, 2016 9:06 am
    If you think there is a problem - Pull the valve cover and spark plug and push it through the rotation cycle while watching the decomp's function.
  • 250rJoe
    by 250rJoe » Mon Aug 29, 2016 10:47 am
    we did that twice already, can we just remove the auto one all together as long as i keep the hot start on the bars?
    by Back2-2 » Mon Aug 29, 2016 1:08 pm
    First - you are talking two completely different systems. The hot start lever is a cable activated plunger on the carb that allows air in the primary circuit to start a bike in a flooded condition. The auto decomp is for starting the bike by opening the exhaust valves slightly to ease the compression on initial rollover.
    I do not see why you could not eliminate the auto decomp system but why would you ? It is there for a reason and set up properly they work
    fine.
    If you inspected it twice I take it that you checked the gap setting and verified it is correct? - it is working as it should ?
  • 250rJoe
    by 250rJoe » Tue Aug 30, 2016 7:20 am
    i left it at my cousins house he said the valves were way out of spec and he was going to shim the valves this week
