CRF 250 swingarm
  • generalsnus
    CRF 250 swingarm
    by generalsnus » Mon Aug 01, 2016 11:44 am
    My swingarm on my CRF 250 2005 is beaten and needs to be replaced. Does a 2007 swingarm fit on my bike, that is with the 2005 suspension and linkage?
    A previous owner got a rear rim from an CR250 2000-2001 I think and I think I need other wheel spacers aswell. This is because when I mounted the wheel and locked it up the swingarm got compressed a little bit, I assume it should be a tight fit without having the svingarm compress towards the wheel?
    Does anyone over here have any suggestions which wheel spacers I should get in order to get this working properly?
  • chopper
    by chopper » Sun Aug 07, 2016 3:54 pm
    Yes the 07 swingarm will be a direct swap when coupled with your shock and linkage.
    The 2000-01 rear wheel is also a direct swap as long as you use the OEM spacers.
  • generalsnus
    by generalsnus » Fri Aug 12, 2016 8:27 am
    Does the CRF and CR share the same spacers? I need new ones but the partsnumbers are different. Though on one shop they sell spacers that fit both CRF 04-09 and CR 00>
  • chopper
    by chopper » Fri Aug 12, 2016 7:50 pm
    Spacers should be the same for the models you have listed.
