07 crf250r gearbox problems after rebuild
  • tcloke90
    by tcloke90 » Sat Apr 09, 2016 2:09 pm
    Hi guys looking for help on 07 crf250r after bottom end rebuild while riding changing into 4th gear it goes to neutral when i put the trans together everything spun freely on shift drum checked the shifter mechanism seems to move when gear shifter moves
    Cheers tim
    by JimDirt » Sat Apr 09, 2016 9:43 pm
    Its possible that you have some shims in the wrong place ?? , or you have the shift drum/forks installed incorrectly ?? , or they were worn and upon re-assembly the issue got worse because of a shim misplacement ?? , sometimes just 1 shim in the wrong place will offset a gear enough to cause this , especially if the gears had any kind of wear on the cogs , if they have any rounding to them the gear will not go all the way to the other and slip back and cause it to pop out of gear
    Also , on the clutch side the sift actuator could be mis-aligned or bent , or the spring not seated properly , what started the issue ?? , it was shifting fine , then it just started skipping 4th ?? , or did it do it from the first after re-assembly ??
    Did you by chance drop the bike on the shifter ??
    Any of these things can cause your issue , if it worked fine before , then it has to be something you did during assembly
    A little more detail as to what happened , like it was working fine and you were speed shifting (without the clutch) and jammed the shifter , or you fell on that side and jammed the shifter , or it did it the first time you rode after rebuild and does it every time , or just occasionally , were you riding easy (trail riding) or at the track ?? , was it on the first ride , or after several uneventful rides ??
    But i am guessing the issue will be in the shift drum , or on the clutch side with the actuator , or a worn cog (the fingers that stick out of the gears)
  • tcloke90
    by tcloke90 » Sat Apr 09, 2016 10:46 pm
    It was on first start up after rebuild and im pretty sure none of the shims come of or moved
    by JimDirt » Sun Apr 10, 2016 5:55 pm
    You could have put one on the opposite side and it moved everything over far enough to cause the issue , if it was not caused by a crash , then the only other options are a assembly mistake , or a worn shift drum or gear cog or shift actuator
  • tcloke90
    by tcloke90 » Mon Apr 11, 2016 1:40 am
    Thanks mate ill pull down it on the weekend
  • tcloke90
    by tcloke90 » Mon Apr 11, 2016 2:05 am
    Ia there anyway to figure out what washers go where
    by JimDirt » Mon Apr 11, 2016 9:48 am
    I would look more at worn parts than shims , as that is what i am thinking is the main issue , the shims should only be sized for each shaft so they should not be easy to mix up , but it can happen
    This is a chart from the Factory Honda Service Manual ,it gives you all the service/wear limits of the transmission components
    This is a list of common issues when a transmission pops out of gear
    Hope that helps some ;)
Users browsing this forum: No registered users and 11 guests
