2010 CRF250R Bike Service (engine problems)
  • Juanrae
    by Juanrae » Fri Jul 24, 2015 2:47 am
    Good day,
    I wonder if someone can assist me.
    I took my crf in for a service as it doesn't want to start after my last ride and assuming it was only the valves that needs to be replaced (note it has 100 hours on it).
    The last time I rode the bike I was only able to bump start it, little to nun compression on the kickstarter. So I immediately turned the bike off and parked it.
    From what I heard if the conrod/big end bearings needs replacing, the bike would have missed and the timing would be out thus the engin wouldn't sound right, but it sounded normal as ever.
    I have already replaced the piston and rings 10 hours ago.
    I got two bike specialists to quote on it and this was the outcome:
    Quote 1:
    Remove cylinder head & inspect valves – both inlets valves
    & seats are worn and need repair/replacing.
    Crank inspection – Big end bearing/conrod assembly has
    Excessive free play & should be replaced asap.
    Parts required:
    2 x Kibble white inlet valves incl spring kits
    2 x inlet valve guides – Back order from Honda – no stock
    Conrod kit – After market
    Timing chain – After market
    Full motor gasket set
    Oil filter, Engine Oil & coolant
    TBR Engineering – crank rebuild & trueing
    TBR Engineering – Cyl head, re-cut seats & make new guides
    Quote 2:
    Remove cylinder head & inspect valves – both inlets valves& seats are worn and need repair/replacing.
    Parts required:
    Optional/Suggestion
    Cyl head – Gas flow/Porting In & Ex
    Skeem ( Hi comp. squiesh)
    Re –Seat Stainless valve kit
    As one can see there is quite a difference between what needs to be replaced - I am not very acquainted with the engine itself and would appreciate anyone help on how to go forward regarding this matter.
    Thanks,
    Juanrae
