JimDirt wrote:Welcome to the site !!![]()
So when you say you checked the valves , and rebuilt the carb , was this back in the beginning of June ? , and you have not checked or done anything since correct ??
If so , was it ridden much during that time or just mostly sitting ??
Did you put FRESH gas in it since June ?? , so basically , has it had fresh gas within the last few weeks ?? , or is the gas in the tank/carb , gas that has been there for a while (a few months??)
What does the bike do when you use the Hot Start Lever ?? , does it make any difference if you use it or not ??
Does the bike backfire a lot on Deceleration ??
Did the bike have this issue since you bought it ?? , or was it fine then it just got worse and worse ??
What is your current jetting ??(Main Jet , Pilot Jet and Needle Clip Position *from the top* , and Fuel Screw Setting **from all the way closed to where it is set**) , and what is your elevation that you live/ride at ??
When you "rebuilt" the carb , what exactly was done to it ??
Also there is a bit of a "special" way to start the bike.
- choke on
- hot start pressed
- 2-3 squirts of throttle
- kick it
Seems to work on mine 5-10 kicks.
