OK, bought a well used CRF250R a few months back, it ran good but had trouble starting, got heads done with all new parts and began starting like it should. After heads were done and installed it began blowing oil out of the trans-side case vent, (the bottom vent tube). Thought blow by was the cause so had a leak-down test done and confirmed bad rings. Ordered and installed new cylinder, piston and rings along with new clips for wrist pin. After all assembled, still leaks oil out of bottom vent. Went back over everything that could be a problem and could only come up with maybe rings are lined up with one another. Haven't been back into it to check that yet, but it is literally the last thing I can think of to be the cause of my problem. Been in and out of this motor many times to check all parts and gaskets over and over, cannot come up with a reason or solution for the oil leak. Please help and give me some ideas on what I'm missing or haven't looked into yet. I'm about to just run it til it explodes or start looking into KTM!!!
Thanks for any help you can offer fellas,
signed, a very frustrated Honda rider....
