my 2009 crf250R leaks fuel, please help
  • hamish98
    by hamish98 » Tue Oct 28, 2014 2:50 am
    i have recently purchased a 2009 crf250R and when ever i lay it on its side on its stand to wash it i find that it leaks alot of fuel and floods when i try to start it after. just wondering if this is normal and how i can stop it
    by JimDirt » Tue Oct 28, 2014 6:30 am
    Either your Needle/Seat is sticking , or the float (attached to the needle/seat) is out of adjustment
    You will need to pull the carb , and reset the float level , the process is shown in the manual , if you dont have a Float Level Gauge http://www.crfsonly.com/catalog/product ... ts_id/4092 you can just use a adjustable caliper or ruler
  • Halen
    by Halen » Sat Nov 15, 2014 6:27 am
    I have the same problem with my 09.
    Even leaning it against my leg when I heave it up on to a stand will cause a bit of leakage.
    Was told it's a common problem..
    Later... Van
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
