Different year parts fit together?
  • Trotts780
    by Trotts780 » Mon Jun 09, 2014 6:20 am
    Hi I've got a 04 crf250r. I pretty much hosed the bottom half of it and found my crank case cracked inside. I'm looking to buy a left and right case off of eBay from a parts dealer there. He is selling 08 crank cases for same bike. He tells me it fits my 04. Is this true? What other parts work like this?
    Thanks lads
  • MX_RACER1
    by MX_RACER1 » Tue Jun 10, 2014 9:30 am
    Google is your friend!! Using this new, wonderful, space aged tool I found a few things for you.
    The 2004 and 2008 crankcase halves do have different part numbers.
    2004 - 11100-krn-505 R
    11200-krn-316 L
    11191-krn-670 gasket
    2008 - 11100-krn-A10 R
    11200-krn-A10 L
    11191-krn-A11 gasket
    Here is where I think you could use them. OEM Honda bottom end gasket kit - 06115-KRN-A00 covers 2004 - 2009 BUT the OEM crankshaft is only the same from 04-07.
    Here is where I'd take a chance. IF you are getting a complete 2008 bottom end I'd take a chance that it would work. If you are just getting the cases.... I might keep searching for a good set of 2004 cases.
    There are a bunch on fleaBay right now around $200. Hope it helps.
