New CRF's
  • whipit9
    New CRF's
    by whipit9 » Wed Jul 24, 2013 4:47 pm
    Hey guys. I'm looking for a new bike. Fuel injection would be nice! haha but anyways are the newer crf's hard on valves like the older ones? Pro's and con's?
    Thanks Jordan
    DarkCRF
    by DarkCRF » Sat Aug 03, 2013 4:42 am
    Since 2010 Honda have found a good mix for the valves and seat, so in 100 hours mine didn't have move. You can buy with confidence.
    Pros :
    FI systems, Honda system at this best, everything electrical is great an reliable, this bike will never let you down like a Suz or KTM with electrical issue. This one can also be remaped easyly with a HRC tuners if you put some mods on it
    Chassis, the most easy feel chassi of all the bike, front wheel oriented geometry, this bike is really easy to handle and everyone feel confortable the first ride with it
    Suspension, if you weight near 140-160 lbs, the setup is perfect with a nice stock valving, great 48 mm fork tube. Except if your a high level racers, you can ride it safe with some clickers adjustement and stock valving
    Air filters : This now so easy to replace the air filter, lot of place to be sure to don't loose some dirt in the intake boot
    Strong midrange power
    Cons :
    Weak top end power, an aftermarket exhaust, Tassinari AIR4orce and a remap can resolve this easyly
    2010 have a little fuel pump filter and this one should be replace evey years, fixed in 2011
    2010-11 had some crankshaft issue, the best was to replace it after 50 hours with a 2012 one or with a hotrod
    2010-13 The suspension must be springned for your weight to get the best from this front wheel oriented chassis unless you can get some stability issue in some specific momment
Users browsing this forum: Google [Bot] and 1 guest
