Problems!!!
  • Trotts780
    Problems!!!
    by Trotts780 » Thu May 09, 2013 4:27 pm
    Hi everyone.
    I just bought a 04 crf250 from someone. The bike ran fine and started fine when I bought it. But a week later I couldn't get it to start. I checked the plug and was getting spark. And the carb was getting clean fuel. Finally after a couple of hours I can push start it. But when I want to idle in neutral it stalls and won't let me get to neutral. Is this because the bike is still cold? Also it just won't kick start for the life of me. And when I have the bike off and in gear the tire won't spin when I hold the clutch. Any help?!?!?! Thanks
    450man574
    by 450man574 » Thu May 09, 2013 4:53 pm
    Check Valve Adjustment.
    2013 KTM 450 SX-F
    2005 CRF450R
    2007 CRF250R
    2002 CR125
    2005 Brute Force 900
    1999 HD 120"
    2011 ZR-1
    2009 Viper
    2010 F-350
  • Trotts780
    by Trotts780 » Thu May 09, 2013 5:23 pm
    Would that also be the reason I'm only getting like 40-50 compression
    mrmschmit
    by mrmschmit » Thu May 09, 2013 10:59 pm
    Definitely check the valves. Low compression values are indicative of valve issues! Push start.. Rough idling also give it away. I'd guess your intakes have zero clearance. Hope u figure it out !
    2007 CRF250R
    450man574
    by 450man574 » Fri May 10, 2013 2:00 am
    it sounds like classic tight intake valves. which is in reality a loss of compression. verify your decomp is working correctly. once bump started how does it run?
    2013 KTM 450 SX-F
    2005 CRF450R
    2007 CRF250R
    2002 CR125
    1999 HD 120"
    2011 ZR-1
    2009 Viper
    2010 F-350
  • Trotts780
    by Trotts780 » Fri May 10, 2013 8:56 am
    Once I bump start it. It sounds a little sluggish. But I don't think it's decompressing because I can't get to neutral once I'm stop and eventually it will just die out.
