CRF250R 2008 timing problem!
  • pyccak
    by pyccak » Tue Sep 11, 2012 2:13 am
    I opened head cover to valve clearance adjustment
    Exception was only in right intake valve 0.17mm
    I adjusted the timing re-
    Motorcycle not start :(
    What the problem might be?
    can i get a detailed guide to the Timing adjust
    tnx!
    mxracer76
    by mxracer76 » Tue Sep 11, 2012 5:09 am
    Did you set it at TDC before you started taking it apart?
    motosicko
    by motosicko » Tue Sep 11, 2012 6:21 am
    "There are old racers
    and there are bold racers,
  • pyccak
    by pyccak » Wed Sep 12, 2012 9:48 am
    I checked everything 20 times already
    still not start...
    Image Image ImageImage
    by crfsonly » Wed Sep 12, 2012 10:41 am
    1. before this adjustment was the bike starting easily?
    2. has there been any engine damage in recent history?
    3. have you checked for spark, fuel?
  • pyccak
    by pyccak » Wed Sep 12, 2012 11:38 am
    crfsonly wrote:1. before this adjustment was the bike starting easily?
    1. YES(cold 3-5 kicks)
    2.NO
    3.YES
    i only change 1 right intake shims 1.90 to 1.95
    by crfsonly » Wed Sep 12, 2012 11:46 am
    it has to be either valve clearance or timing. check both. remember just one tooth off on the timing will result in hard to impossible starting.
  • pyccak
    by pyccak » Wed Sep 26, 2012 1:27 pm
    At the end I start the bike with carburetor spray :)
    by crfsonly » Wed Sep 26, 2012 1:37 pm
    if after it is started it runs well then starting with carb spray indicates you have a pilot circuit and possible an accelerator pump issue.
