by crfsonly » Mon Jul 09, 2012 4:41 pm
so you are able to kick through with no compression? when you are checking the timing are the cam lobes facing the carb? if so, when the cam is set to TDC, lobes facing the rear, is there clearance under all four valves? if so, and you still have no compression then you should pull the cam and inspect the auto decomp. if that looks functional then you have to pull the head and inspect the valves and piston.
