I would be a little careful going from a sitting position to a standing going up the face of the jump.
Monkeywrench wrote:You have gotten some good advice here.
I think one of the reasons you find you're less apt to pull on the bars when you wait until going up the face before standing, is that you're just about eliminating your arms from the equation. As you stand, your legs are supporting your weight and doing the work. Wether or not you realise it, you're probably rowing forward while you stand, which is good! (You should be able to look down and see the top edge of your # plate).
If you approach a jump already standing, a common challenge many people just starting out fail to realise is that they need to readjust their body position/body angle. Meaning: imagine a toy dirtbike with a pretend rider on it, in the standing position. Looks fine on flat ground, right? Now tilt the front end up, and imagine his body position. He is no longer vertical/perpendicular to the ground... but leaning back some. If he proceeds up the jump this way, physics cause your upper-body weight to be supported by your arms (so you don't fall bacK). This creates a pulling-back on the bars, which causes your front end to rise.
Try and concentrate on everything the guys wrote above. Great advice.
As you approach the jump, be standing already. Body forward, body weight supported thru your legs, chest over the tank, knees bent slightly (do not lock your knees), head over the bar pad (you'll actually be leaning forward). STAY in this position all the way up the jump, and keep the speed constant (do not speed up, and do not slow down). Once your bike leaves the face of the jump, you will have a natural tendency to allow the bike to come forward a bit, placing your person back in the center of the bike. Try to land front tire just before the rear, or maybe even both tires at same time, but not rear tire first. That creates a slap-down effect which can throw you forward.
Start small, and always abort if you feel uncomfortable or out of position. If you plan to abort, be very careful about deciding before you start up the face of the jump. Chopping the throttle up the face of the jump will result in a nose-down air flight, and very difficult landing. Once you hit the face, you should be committed based on feeling ready to go and comfortable. If the approach to the jump is choppy and you don't have confidence because of it, you risk a lot by making that your learn-to jump. I would find one that's very smooth for starters.
Concentrate on getting used to that forward body position as you go up the face, and keeping your speed smooth. Those 2 parts are very important to the bike's position once you leave the jump.
How does one land those?
woodsman wrote:Monkeywrench wrote:You have gotten some good advice here.
Wow. Never new that. Wish I had. I've always landed back first with the front a good halfoot above it. It hurts, but keeps the bike tracking straighter I thought. I'll have to try your way now. Whatabout jumps with flat landings? How does one land those?
mikey526 wrote:...do not land front wheel first unless you are absolutely sure that the landing is smooth
