Black z400 wrote:Looks like I'm having the same problem on my 06. I just noticed my engine oil being way way overfilled last ride after sitting a month, but my clutch has been going out, and the basket and hub are toast. My bike has been running great though, so I think I'm lucky the bottom end isn't destroyed. When I drained the oil, the transmission was dangerously low. I have yet to replace either seal, but while I'm in there, I figure I may as well replace both. Is there anything else to remove to access the balance shaft seal, while replacing the right crankshaft seal? Also, are any special tools or solutions required to replace the seals, or do I just push them in?
The new seals should puch in with you thumbs. Getting them out, thats a different story. You can get seal pullers which are useful.
Thanks
Black z400 wrote:Thanks for the suggestions, and I understand what you mean with jamming something behind the gear. I believe a penny will work, correct? It seems more often the case that it is the right crank seal leaking, and I think I will go with replacing just that and see what happens from there. How much is a seal puller, and if I don't get one, how else do i go about removing it? Is it necessary to put any kind of sealing solution on the seal while pushing it in, or just press it right in? Still waiting on the manual until I can do anything...
Thanks.
Users browsing this forum: Bing [Bot] and 5 guests
