Sand in throttle
  • zedycus
    Sand in throttle
    by zedycus » Mon Nov 12, 2007 6:24 pm
    Hey guys, I just recently picked up a brand new 06 CRF250R. It's my very first bike. I've been out on it four times so far. I'm having a blast with it.
    Today, I took her out to Gorman and got a nasty fall. When the bike fell, the throttle fell into sand. Now I have sand in the throttle. When I open the throttle all the way, it gets stuck. I couldn't figure out how to get all the sand out.
    My question is how do I disassemble the throttle so that I can get the sand out. I looked at my manual couldn't find anything on it. Thanks in advance.
    Zed
  • redrider911
    by redrider911 » Tue Nov 13, 2007 3:28 pm
    It's a big pain in the rear end!!. Remove the two bolts that clamp the throttle to your handle bars and separate the assembly. There is a white piece inside that the cables run on that might pop out, or stick to one side. Pull the cables out from the throttle tube. Clean/grease as needed. Good luck putting back together.
    KevinM
    by KevinM » Tue Nov 13, 2007 7:42 pm
    Red, here's a link to a pretty decent throttle maintenance HOw-To on Transworld MX's site. Check it out.. then get to it!
    http://www.transworldmotocross.com/mx/h ... 55,00.html
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
    mikey526
    by mikey526 » Wed Nov 14, 2007 5:17 am
    Don't tighten the clamp bolts on the throttle too tight! Don't tighten the clamp bolts on the throttle too tight! Don't tighten the clamp bolts on the throttle too tight! There is a little heli coil like thing in it that is supposed to be glued to the housing, but when I was tightening mine, that broke and so the bolt would stay tight. It fell out when I crashed so now I think I have to buy a new lower throttle housing...
    Mike
  • zedycus
    by zedycus » Wed Nov 14, 2007 4:43 pm
    Hey thanks a lot guys, I took it apart, it wasn't as technical as thought it to be. I cleaned it and greased the ends of the cable. I don't have cable lube so i used grease on the cable. Not the entire cable, only what is exposed. Would that be an issue? And as far as tightening the throttle clamp. I did it really tight. I'm going to loosen it up as soon as I finish typing this. Thanks again.
    Zed.
    by 124 » Thu Nov 15, 2007 5:33 am
    Never put grease in the throttle barrel, actuators, or cables. It won't hurt it directly, but will attract dust/dirt like a magnet. Use silicone spray or equivalent cable lube. Depending on your conditions, you may want to just leave it clean and call it a day.
