Suspension Database
    Suspension Database
    by crfsonly » Thu Apr 12, 2007 6:29 am
    Please keep other info out of this thread. Only answer the questions. Copy and paste to keep format uniform.
    Note: Clicker adjustment should be expressed in clicks from full hard.
    Year:
    Rider Weight:
    Rider Weight with Gear:
    Riding Style (i.e. Desert, MX):
    Forks Raised in Triples:
    Rear Tire Size:
    Aftermarket Triples/Offset:
    Fork Springs Wt:
    Fork Spring Brand:
    Fork Oil Amount:
    Fork Oil Brand & Weight:
    Fork Compression:
    Fork Rebound:
    Fork Valving:
    Shock Spring Wt:
    Shock Spring Brand:
    Shock Hi speed Compression:
    Shock Lo speed Compression:
    Shock Rebound:
    Shock Valving:
    Shock Oil:
    Race Sag:
    Preload:
    slowboy06
    by slowboy06 » Sun May 13, 2012 6:44 pm
    Year: 2008
    Rider Weight: 147
    Rider Weight with Gear: 150
    Riding Style (i.e. Desert, MX): MX
    Forks Raised in Triples: Stock
    Rear Tire Size: Stock
    Aftermarket Triples/Offset: Stock
    Fork Springs Wt: Stock
    Fork Spring Brand: Stock
    Fork Oil Amount: Stock
    Fork Oil Brand & Weight: Stock
    Fork Compression: 7 from hard
    Fork Rebound: 12 from hard
    Fork Valving: Stock
    Shock Spring Wt: Stock
    Shock Spring Brand: Stock
    Shock Hi speed Compression: 1 from hard
    Shock Lo speed Compression: 9 from stiff
    Shock Rebound: 7 from hard
    Shock Valving: Stock
    Shock Oil: Stock
    Race Sag: 100mm
    Preload:
    DarkCRF
    Re: Suspension Database
    by DarkCRF » Mon May 14, 2012 3:16 am
    crfsonly wrote:
    Year: 2010
    Rider Weight: 190 lbs
    Riding Style (i.e. Desert, MX): MX novice
    Forks Raised in Triples: 0mm
    Rear Tire Size: 10090R19
    Aftermarket Triples/Offset: OEM
    Fork Springs Wt: .46kg/mm
    Fork Spring Brand: Factory Connection
    Fork Oil Amount: 360cc
    Fork Oil Brand & Weight: Factory Connection FF5 / 5W
    Fork Compression: 10
    Fork Rebound: 10
    Fork Valving: OEM
    Shock Spring Wt: 5.3kg/mm
    Shock Spring Brand: OEM
    Shock Hi speed Compression: 2.5
    Shock Lo speed Compression: 11
    Shock Rebound: 10
    Shock Valving: OEM
    Shock Oil: Factory Connection GSF / 2.5W
    Race Sag: 108mm
    HSSD: 0
