help me lower my 250
  • MXguitargod7
    by MXguitargod7 » Tue Mar 27, 2007 3:35 pm
    im 5' 3'' close to 4'', but have a hard time fitting on my 250... my forks are shuved up and my sag is soft.. what else can i do?
    07 CRF250R
    Honda Racing. RIDE RED.
    Alpinestars.
    Answer Racing.
    woodsman
    Grow
    by woodsman » Tue Mar 27, 2007 6:17 pm
    Grow up! :lol:
    Check in the crfsonly store under suspension for your motorcycle and it should list a lowering link.
    Currently, 05 450X
    KevinM
    by KevinM » Wed Mar 28, 2007 7:29 am
    Yes, changing the shock linkage will lower the rear. You'll need to reset your race sag after changing the linkage out.
    Some female pro AMA racers actually have the subframe cut by about 1 cm and re-welded. That's not a home remedy for sure... but an option if you really need it. I'd try to find someone who really knew what they were doing before I had the sub-frame cut though.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
    zak13
    by zak13 » Thu Apr 05, 2007 9:26 am
    zak13
    Re: help me lower my 250
    by zak13 » Thu Apr 05, 2007 9:28 am
    MXguitargod7 wrote:im 5' 3'' close to 4'', but have a hard time fitting on my 250... my forks are shuved up and my sag is soft.. what else can i do?
    i feel ya bro im the exact same heigth and i cant fit on the 250 also does any one know where i can get a lowering link for the 2007 model and does any one know if the 2006 link will work on the 2007 model
    zak13
    by zak13 » Wed Apr 11, 2007 4:13 pm
    get a lowering link that should lower it 1.75 inches
  • _06_crf_250r
    by _06_crf_250r » Thu Apr 12, 2007 10:57 am
    I would try shaving my seatfoam if I were you. Ihave never done it but I hear it can be done with one of those electic turkey carving knives.
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
    zak13
    by zak13 » Tue Apr 17, 2007 3:28 pm
    if i shaves my seat will i have to get a new cover or can i use stock covers
  • tony06CRF250R
    by tony06CRF250R » Thu May 31, 2007 1:39 pm
    hi there i have an 06 CRF250R I am 5ft2' and weight 56kg without gear and about 65kg with gear...this is what i have done....
    STAGE ONE
    first i put the kouba link CRF3 on which lowers the rear and then slid the forks through the clamps by 1 inch.
    DO NOT PUT TOO MUCH RACE SAG....it will make the bike turn like a harley or a KTM!! 2 or 3 turns from standard should be OK. i found that because the rear is lower due to the link the sag will be OK. static sag of about 47mm should be Ok...dont worry about trying to get 100 of total sag.
    Put all 4 clickers is fork comp and rebound to 15 and rear comp and rebound to 15
    Result..the bike turns like ist on rails due to low CofG.
    if it bounces from jumps turn the rear rebound in to 13 then 11. maybe turn the front rebound in to 13.
    STAGE 2
    Next step change the inner chamber fork oil in the front forks to 2.5Wt....this is like a revalve...the forks will be really plush...fantastic!!!
    STAGE 3
    get a supsension expert to supply correct front and rear springs.
    standard is Front 0.45 Rear 5.30
    I used
    Front 0.40 Rear 4.70
    STAGE 4
    for MX only i removed the link and returned the bike to normal as i could now get the correct sag. for enduro i refit the link and lower the forks..takes 20 mins.
    another tip...when trying to start the bike when warm after stalling or a crash...wait 5 to 10 secs for the carb to fill up... pull in the clutcgh as well and use the hot start.
    all the best
    Tony
    06 CRF250R
    Boyesen quick shot
    white david baily graphics
    Tony
    sold my 06 CRF250R
    waiting for my 2010!!
  • tony06CRF250R
    by tony06CRF250R » Fri Jun 01, 2007 5:06 am
    Here is another tip.....I use a works connection holeshot device. with the front held down its really easy to start the bike....an added bonus is great starts and no wheelies!!! I was getting really great starts then everyone got one!!
    cheers
    Tony
    Tony
    sold my 06 CRF250R
