athena 280cc kit
  • yammarslammar
    athena 280cc kit
    by yammarslammar » Tue Jan 23, 2007 3:19 am
    has anyone tried the athena 280 kit? if so what do you think? does the bike still rev to the moon? Please let me know, thanks.
  • _06_crf_250r
    by _06_crf_250r » Tue Jan 23, 2007 3:17 pm
    say good buy to ever racing it
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
  • yammarslammar
    why
    by yammarslammar » Wed Jan 24, 2007 12:59 pm
    why can't you race it? please explain.
    by Old Dude » Wed Jan 24, 2007 3:36 pm
    I think he is referring to big bore kits not being allowed to run in the 250 or lites class. They are legal however in the Vet and older classes where its run what ya brung.
  • Vanrock
    by Vanrock » Thu Jan 25, 2007 2:04 am
    Wat was the point of buying a 250 if you wanna give it a biger bore, why didn't you just get a 450
    2007 CRF250R
  • yammarslammar
    big bore
    by yammarslammar » Thu Jan 25, 2007 3:26 am
    ride harescrambles in tight eastern woods, small bike is alot better in that situation. Had a crf 450r and prefer the 250r.
  • redrooster65
    by redrooster65 » Thu Jan 25, 2007 6:06 am
    Vanrock wrote:Wat was the point of buying a 250 if you wanna give it a biger bore, why didn't you just get a 450
    30 Pounds
  • FTGraffix
    by FTGraffix » Mon Jan 29, 2007 7:18 pm
    Yamaha, great question. I have my new Atena kit, but I have yet to install it. My bud, Al at Reactive suspension, told me it will give me low end and mid, but I may loose a hair off of the top. I ride with all big bikes, on small tracks, so I need the speed out of the corners.....I think!?!?! Anyone else have one on their 250
  • yammarslammar
    athena 280cc kit
    by yammarslammar » Thu Feb 01, 2007 1:01 pm
    Graffix, please let me know how your bike turns out when the kit is installed. I can't believe there is not alot of people who has tried this kit :!:
    Clint-137
    by Clint-137 » Fri Feb 02, 2007 11:23 am
    its great, just put mine on 3 days ago, a lot more torque. and i havent really hit it hard yet since its no broken in, i have blipped the throttly a few times and it is realy nice!
  • steinstyle
    by steinstyle » Fri May 04, 2007 5:08 pm
    great low end and mid power it's super fun and fast. I need to gear it a little taller. Go from a 13/51 to a 13/49. now i need to fix the bog.
  • ThumperX
    by ThumperX » Fri May 04, 2007 8:46 pm
    steinstyle wrote:great low end and mid power it's super fun and fast. I need to gear it a little taller. Go from a 13/51 to a 13/49. now i need to fix the bog.
    If your feeling the bog after dropping to the 49 try adjusting the fuel screw, it solved my issue without tearing down the carb.
    05' CRF250X
    07' CR250R
    02' CRF450R
  • FTGraffix
    by FTGraffix » Sun May 13, 2007 6:32 am
    Well, you may have seen my other posts. Lotso torque... but after 3 hours my base gasket is leaking. :-(
