rear gearing 51or 52??
    Kountry boy
    by Kountry boy » Sat Jan 20, 2007 11:52 pm
    i have a 06 that im racing in the vet class,the bike runs great, pulls great holeshots . my question is i,ve been kickin around the idea of a gear change .go one more tooth in the rear would this help me keep the rpms up in the corners? i know it means more shifting but i think being in 3rd and 4th is better than 2nd and 3rd will i loose much of the holeshot??
  • Vanrock
    by Vanrock » Sun Jan 21, 2007 3:54 am
    I have thought about this my self but droping teeth on the back. But honda have got it right the first time. why change it
    :D
    2007 CRF250R
  • MX26
    by MX26 » Mon Jan 22, 2007 3:25 am
    I ride a fairly tight track and I bumped my rear sproket up 2 teeth to a 53 and I love it. Yes there is two sections where I get to 5th but getting out of the corners is a lot better.
    In my opinion.
  • _06_crf_250r
    by _06_crf_250r » Tue Jan 23, 2007 3:06 pm
    Gearing is a feeling type of thing. Consider what tracks you ride, how tight the corners are any long straights?
    You say you get good holeshots and it feels good don't change it. I looks to me you are eager to mod your bike. Mods are good some make your bike preform better and most make it look different. Your going to need your money for gas, oil, and repairs. so spend your money wisely. Look through the forums for good mods it has been discussed alot
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
    MotoZack318
    by MotoZack318 » Tue Jan 23, 2007 3:45 pm
    I just put a 52 on my 05R but have not ridden it yet (snow). I read that it will help fill in some of that annoying gap between 2nd and 3rd gears. I'm also hoping it will allow me to better launch out of bowl turns in 3rd without using so much clutch. I just waited until my chain and sprockets were worn out before making any gearing changes.
    South-Eastern Idaho sucks, so Californians should move somewhere else! :)
  • tony06CRF250R
    by tony06CRF250R » Tue Jan 30, 2007 10:17 am
    I have tried the 52 tooth sprocket twice now. On both occiasions I have changed it back after the race.
    To be honest I cant tell the difference in the gap betwean 2nd and 3rd.
    I find with the standard 51 sprocket it corners better as the engine lugs more and can torque round the corner, giving more control.
    Give it a try and see what you think.
    Also I had to shorten the chain 1 link and also extend the wheelbase to get the right chain tension.
    Cheers
    Tony
    06CRF250R
    Clint-137
    by Clint-137 » Fri Feb 02, 2007 11:40 am
    ya i do a lot of drag racing, helpin my hole shots.. and i have a 14, 53 and it works real great, pulls really nice.
    280cc big bore kit.
    Hot cam
    white bros. carbon pro2
    Power now system
    boyesen quickshot
    EBC clutch
    customized race tech suspension
    renthal twin wall
    universal top triple clamp...
  • Crf250fRidr
    by Crf250fRidr » Tue Feb 06, 2007 5:57 pm
    I love the way that my bike is geared. Sometimes i wish that 5th was a little taller and first was lower. It'd be nice to have the topend on the long fast sictions of desert, but it would be nice to not feather the clutch so much when i'm in super tight single track.
  • Hammer
    Gearing
    by Hammer » Thu Feb 08, 2007 4:41 pm
    If you on the bulky side like me gear up, you won't be disappointed. If you do go up, go with the ironman sprockets. they're lazer cut stainless steel. Very light and last forever ! Be sure to go all new when you do, even a chain.
    If you can't ride good, then look good riding
    In the morning, we ride.
    2020 crf250r
    04 crf 250, power now, Icat, full fmf ti exhaust, hot cam. Tom Morgan ported head,New ti valves, springs.
