HELP .... VALVES !!!
  • WARRIOR
    by WARRIOR » Fri May 15, 2015 9:14 pm
    WELL ....
    I have everything back together ..
    I FINALLY got it started.. warmed it up
    took it for a roll I feathered the throttle and clutch to get moving.. putted around and then was rolling and hammered the throttle at a roll.... it will just bog ( several attempts ) until I let off the throttle... if I slow roll the throttle it would take off and then I could hit it once the R's were up and it was fine ...?????
    when it run fine I still had to mess with the choke to get it started ( started more like a 2-stroke ?) even had to feather the throttle to start it before all this ... now it's A LOT worse ??? HELP :( PLEASE !!
    Back in the sport after 25 years !!
    2004 CRF250R
    by JimDirt » Sat May 16, 2015 11:35 am
    See my reply in your other post , i am guessing Timing is off
