06 CR85 Waterpump help
    by krisrtch » Sun Oct 24, 2010 3:28 pm
    Does anyone have the service manual page they can share for the water pump seal I have a wheeper and need to see what i need to replace or fix leaking pump Thanks!
    riddler9
    by riddler9 » Mon Oct 25, 2010 8:42 am
    did this once before, takes about 30 minutes. biggest thing is don't mess up the seals, and if you are replacing the inner shaft bearing you need a puller. Seals and bearings call for a tool, but if your careful and have the right sockets you can use them instead.
    torque values:
    water pump impeller 7 lbf-ft
    coolant drain bolt 6.5 lbf-ft
    remove pump
    remove left crankcase cover
    use tool to hold flywheel to remove impeller - tool is 07725-030000 (or make something)
    remove right crankcase cover
    remove water pump shaft from right cover
    this will expose water seal and oil seal (replace if needed)
    water pump shaft bearings are in the right cover and crankcase
    if you need to change the bearing on the right crankcase side, they call for a 7 mm bearing remover (07931-KA30000) but I used a tool from NAPA
    to replace seals:
    remove pump shaft bearing from right cover
    drive out water and oil seals together
    coat outside surface of new water seal with trans oil and grease seal lip
    drive in new water seal (calls for tool 07965-415000A) but a socket works
    coat outside of new oil seal with trans oil and grease the seal lip
    install oil seal into crankcase cover
    drive new water pump shaft hearing into cover
    install water pump shaft into crankcase cover
    install right crankcase cover
    install new copper washer onto pump shaft
    hold flywheel using special too and install impeller
    install pump cover/gasket
    hope that helps.
    Official Lurker
    steakcrf77
    Waterpump service page 06 CR85
    by steakcrf77 » Mon Oct 25, 2010 8:43 am
    Whats your email?
    by krisrtch » Mon Oct 25, 2010 10:33 am
    Thanks a bunch man that is exactly what I needed!
    steakcrf77
    by steakcrf77 » Mon Oct 25, 2010 10:51 am
    No problem. Happy to help. I am sure Ridder9's helps as well. I just sent some pictures along with it.
    by Aussiecrf230 » Thu Oct 28, 2010 2:45 am
    A CR front sprocket that is worn makes a good tool to lock primary gear.
