2003 tt-r125 troubles
    hondafan
    by hondafan » Wed Nov 05, 2008 6:01 pm
    Hey guys whats going on? i bought this TT-R125 as a playbike and it has been running fine up until now. when i roll on the throttle it bogs way down. when the choke is pulled up it runs like a champ. i have tried bigger main jets and bigger pilot jets. and it still does it? i have also replaced a couple of parts within the carburetor that looked worn or damaged. it is starting to tick me off because i have tried alot and nothing helps. if anyone has anything i would appreciate it.
    2008 crf 450
    sold-2001 cr250, 2004 crf150, 2003 cr250, 1991 KX80, 2003 TT-R125
    marks crf
    by marks crf » Wed Nov 05, 2008 8:35 pm
    check the air filter, spark plug, and clean the carby out
    my #00
    5th gear PINNED on the 250
    6th gear PINNED on the 125
    hondafan
    by hondafan » Wed Nov 05, 2008 8:52 pm
    Thanks marks but those were the first things i checked, along with the fuel filter. i replaced the spark plug when i bought the bike (about 6 months ago). but do you think it may have gone bad in this short of time, and would cause the motor to bog at half throttle? its possible i guess. i will get a new plug tomorrow. thanks again!
    2008 crf 450
    marks crf
    by marks crf » Thu Nov 06, 2008 12:14 pm
    clean the carby out and if it still runs like crap check the electrics
    my #00
    hondafan
    by hondafan » Fri Nov 14, 2008 4:12 pm
    well in about an hour i am selling it, so after that i wont care... it will just be the buyers problem.
    2008 crf 450
    by [email protected] » Fri Nov 14, 2008 4:34 pm
    Isn't the new buyer going to ride it first, or what ?
    I'm sure you're going to tell them that "it really bogs unless the choke is all the way out", right ?
    My wifes bike is a very good running 04 TTR 125 that's been as trouble free as a paper weight.
    Changing jets when a bike ran great before is never a fix unless temps and elevation vastly changed.
    Though you've cleaned the carb it is almost always a clogged jet(s) when you need the choke on to keep the bike running, the choke gives it a lot more fuel which it obviously is lacking. When it's not clogged jets with that sympton it's usually bad fuel.
    I'd drain the float bowl, dump the gas and start over, if no luck then a carb cleaning with compressed air in every jet and orifice, including the choke cable entrance.Look at the excellent TTR owners manual which is really 3/4 of a shop manual to be sure the carb goes back together right, there's a plastic part in the float bowl that can be put in wrong.
    Doug
    marks crf
    by marks crf » Fri Nov 14, 2008 5:13 pm
    hondafan wrote:well in about an hour i am selling it, so after that i wont care... it will just be the buyers problem.
    done that to my old yamaha sold it because it kept on bogging but after say 30 minutes of a good ride it nearly all goes away.
    my #00
    hondafan
    by hondafan » Fri Nov 14, 2008 9:40 pm
    oh yeah, i told him that it bogs before he was even ready to buy it. http://oklahomacity.craigslist.org/mcy/908909499.html
    and Doug i did all that except the compressed air thing. i was just tired of working on it and the guy was desperate... plus i needed the extra cash.
    i have to say i wont miss it, but it sure ran good when it did run.
    2008 crf 450
  • crf100rider21
    by crf100rider21 » Sat Nov 15, 2008 7:20 pm
    I know the problem!
    It was a yamaha! :lol:
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    hondafan
    by hondafan » Sun Nov 16, 2008 7:13 am
    I know the problem!
    It was a yamaha!
    actually it was a mikuni. the motor was good along with the rest of the bike.
    2008 crf 450
