I have a 2005 450X I bought new. It has never liked to start and takes 5-10 seconds of starter to get going. It will die a few times and generally run like . until its hot. Then it runs fine.
At higher elevation (3500ft) it starts up in 2 seconds and never dies once.
I already have my fuel screw at 1.75 turns out. What's the range on it? I've heard if you need to exceed 2 turns you need a larger pilot.
What should I do next? Hoping to do it with a simple jet and not a $75 JD kit.
___________________________________________________________________________
What is your elevation ?? 500ft
What type of riding are you doing ?? trails
What is your Fuel Screw set at ?? 1.75 OUT
What jets are in it (Pilot/Main) ?? 45/155
What is the Needle Clip Position ?? (IE: 3rd from top , etc.) NCVS #3rd
Was the bike running fine then just started doing this ?? , or was it like this when you bought it , or after sitting for a extended period ?? Always been like this
Have you actually pulled the carb and cleaned it (removing all the rubber parts like Fuel Screw O-Ring , Slide , Floating Slide Plate O-Ring , gaskets , jets , and flushed everything with carb cleaner and blown out with air) ??? Yes
Do you have a Manual ??? (Yes/No) Yes
Have you lifted the subframe and airbox , and looked down the throat of the carb and twisted the throttle to see if the accelerator pump is squirting ?? , and if it just barely misses the slide and does not hit it ??? No
When/if you took the carb apart , did you note which way the floating plate is on the slide ?? , was the hole at the bottom ?? , or the Top ?? , it needs to be at the bottom .. No
Did you drain and flush the tank and put FRESH Premium in ?? Yes
