I bought this bike for my girlfriend and have done a little jetting before this bike. It is a fun bike but mostly midway though throttle pulling up hills it falls on its face. Keeps running but sounds like crap and will not accelerate. It mooatly happend with altitude. We can start in the desert at 2500 at the beginning of the day and end up near 6000 within a couple hours. Referee to the stock jetting chart. And said to lean out the main and change needle. Had stock jetting so I went down to 135 like manual says. Went up in pilot just to see if could feel anything down low. Ran the same. Kept main at 135 and dropped pilot down as well to 35 from the 40 I had just installed. Ran the same again. Adjusting fuel screw each time from cracked open to full 2 turns out and never feel any difference.
Bike has stage 1 cam
Stock repacked exhaust can and omg end cap for sparkies
What is your elevation ?? ______2500-6000________
What type of riding are you doing ?? ________desert/mountain___________
What is your Fuel Screw set at ?? _______1.5-2_____
What jets are in it (Pilot/Main) ?? __38____/___135___
What is the Needle Clip Position ?? (IE: 3rd from top , etc.) ______3rd______
Was the bike running fine then just started doing this ?? , or was it like this when you bought it , or after sitting for a extended period ?? ____________ran like this when purchased__________________________________________________________________________________
Have you actually pulled the carb and cleaned it (removing all the rubber parts like Fuel Screw O-Ring , Slide , Floating Slide Plate O-Ring , gaskets , jets , and flushed everything with carb cleaner and blown out with air) ??? __________________yesss_____________
Do you have a Manual ??? (Yes/No) ___yesss__/_____
Have you lifted the subframe and airbox , and looked down the throat of the carb and twisted the throttle to see if the accelerator pump is squirting ?? , and if it just barely misses the slide and does not hit it ??? ________________________yesss__________________
When/if you took the carb apart , did you note which way the floating plate is on the slide ?? , was the hole at the bottom ?? , or the Top ?? , it needs to be at the bottom .. __________bottom__________
Did you drain and flush the tank and put FRESH Premium in ?? ____________yes______
Was the bike sitting for a long time (over 3 months with gas in it , if so see above last 2 questions) ?? __________no__________
If the bike was recently purchased , was the prior owner up front and explained the issues with the bike ?? , and if it was recently purchased how long have you had the bike , and were the issues present then ?? ______________no issue_________
