Recently bought an 05 250x, and am trying to make the bike run as good as possible. It has the air box cut
air pump deleted
aftermarket exhaust (not sure what kind)
AP wire mod.
Bike has a k&n filter but I want to change back to a foam filter, (maybe a no toil super flow kit)
I typically ride anywhere from 1500-4500 ft (socal) elevation in 50-90° temps.
it currently has 130 Main
40 pilot
100 slow 68 starter
65 leak
Needle clip 3rd position I believe.
According to Rick Ramsey's site most altitude adjustments are done with the needle clip, and fuel screw. But if I go up in altitude do I need to richen, or lean the jetting? And vice versa.
On the mains the bigger the number the richer correct?
I'm a total noob to carb tuning, all help is greatly appreciated
