timing chain problem crf 250
Posted: Mon Jan 29, 2018 3:47 am
Hello,
I was trying to finis the reassembly of my bike following a change of piston and timing chain on my 250 crf 2013.
But I can not put the timing chain back on the camshaft sprocket, chain is way too tight.
Or if I get there (on the sprocket), I can not push back the bearing into its housing to put the camshaft in his normal position ...
I counted the number of links, 106 and compare the length with the old chain it's ok. \
I've also opened the lower carter to ensure the chain was properly set around the crakshaft sprocket and yes
The chain tensioner is at the moment unmounted.
Help me please, Do you have a trick, is it normal ?
Sorry for my english.
