06 CRF250R jets
  • Redfishwhisperer
    06 CRF250R jets
    by Redfishwhisperer » Sat Nov 04, 2017 6:46 am
    I have a new to me 06 CRF250R and can't seem to find anything that compares to what I have found in the carb. There are signs of Tokyo mods (bowl cap, air screw, red timing spring) but I have no idea if they are the ones that put the following in it.
    NHFS 4th clip from top
    42 pilot
    182 main
    68 starter
    42 leak
    I have only ridden it a few times and had an EXTREMELY touchy slow speed throttle response. I decided to check the valves and found the intake bottomed out so I sent them to be reworked. In the meantime I am checking the carb and would like to try and get it close before the head comes back. Any input is appreciated.
    Re: 06 CRF250R jets
    by crfsonly » Sun Dec 03, 2017 7:22 pm
    Not sure exactly what you mean by "touchy". However, the best jetting we have tested is the JD Jetting.
    https://www.crfsonly.com/catalog/produc ... ts_id/1095
    Often used bikes have a number of carb issues. AP has a bad diaphragm, floating valve seal is bad or installed incorrectly, pilot jet is clogged, etc.
    Ken
