by Dirtdiver73 » Wed Apr 03, 2013 5:00 pm
Sounds like you have two problems first is a clogged pilot jet and the other is your fuel screw setting. Do you have an aftermarket or stock fuel screw? Never the less, your problem sounds like a clogged pilot jet. The plug is black because your idling the bike with the choke on. Clean or replace your pilot jet and get an inline fuel filter. Turn your fuel screw in all the way (lightly seated) then turn it 1 1/2 turns out. This is a good starting point. You can't really properly adjust your fuel screw until your engine is at operating temp. When posting your posts make sure you include other mods such as exhaust, air box, cam, etc. Good luck. Let us know how it works out.
A bad day of riding beats a good day at work!
