Having a bit of a hard time getting the carb set up correctly on my 2009 CRF250R.
Plug looks lean to me?
http://s39.photobucket.com/albums/e180/ ... 2012%2013/
50-60 degrees F, 30-50 % humidity at sea level.
Pilot circuit is rich - fuel screw all the way in and not changing idle?
I know "on the stand" is not a proper way to diagnose but it spits fire at WOT.
While riding it feels pretty good, not much noticeable popping but I don't bounce off the rev limiter much.
Bog is still there once in a while. Bike has around 15hrs, valves are spot on and everything is stock
other than Loud Mouth and Dyno Jet Stage 1 kit which is 185 main, 48 pilot, clip 4th from the top.
Also did O-ring mod and put in a 55 leak. Burning Sunoco Standard Purple(110 leaded).
When jetting was stock 185 main, 42 pilot, 70 leak. Plug still looked lean and had some decel pop and standard off idle bog.
Also maybe considering going to a 37mm carb.
