Big bore jetting?
Posted: Fri Jan 06, 2012 12:09 pm
by CRFPitbull
Hey can anyone tell me what jets to run on my 2007 CRF450R?
I've installed a Cylinder Works 488 big bore kit and i have a powerbomb header, quickshot 2 and nothing more!
Thanks in advance to anyone who can help!
Posted: Wed Jan 11, 2012 2:21 pm
if your bike was well jetted prior to the big bore install you should be able to get by with either fuel screw adjustments or going one larger on the pilot. test this first and if the power falls off up top then go one larger on the main too.
good luck!
jetting
Posted: Thu Jan 19, 2012 9:47 am
by CRFPitbull
im running a 45 slow jet up from the stock 42 and the stock 178 main jet with 1 3/4 turns out on the fuel screw. I was told not to ride the bike until i jet it??
Posted: Thu Jan 19, 2012 12:39 pm
if it is running lean then you do want to wait until you get it jetted correctly. with the larger pilot and the fuel screw set to 2 turns out test it and see how it responds. you may have to go one larger on the main as well. again, this is assuming the carb was correctly jetted prior to the big bore kit install.
thx
Posted: Wed Jan 25, 2012 2:21 pm
by CRFPitbull
going to test it out on a ride to the Rock Inn! Thanks Ken....
tips
Posted: Wed Jan 25, 2012 2:25 pm
by CRFPitbull
Any tips on breaking it in?
Posted: Wed Jan 25, 2012 2:35 pm
use organic oil. three sessions of 15 minutes riding with and cool down periods in between. generate as much compression as you can by going up hills and down hills. when going down use engine compression braking. don't idle it for long and don't run it at the same RPM. don't hit the rev limiter. don't baby it either.
change the oil after these three cycles.
