AP mode1 bring backfire and a litle bit bog mid rev
    skylos_mauros
    by skylos_mauros » Sat Sep 10, 2011 12:02 pm
    Hello again from Serres-Greece
    First thanks a lot for your help with my other problem....everything solved.
    So i decide to apply APmod1 ....i ve made it and know backfire appears on my exhaust and at middle rev the engine bogs..
    I have undo everything as it was or there is any solution with the air screw....?
    Changing jetting is a little bit hard here in Greece.
    Thanks in advance and i apologize for my poor English-Bike is a Honda Crf450r 2005 Cylinder works big bore kit.
    cheers
    Skylos_Mauros
    by crfsonly » Sun Sep 11, 2011 7:36 am
    the "air screw" on a 4-stroke is actually a fuel screw. you can adjust it but it only affects the pilot circuit. which will be idle and off-idle to 1/4 throttle. if you are having issues 1/2 throttle then you need to look into your needle and main jet.
  • Keith72
    by Keith72 » Sun Sep 11, 2011 3:41 pm
    Undo the AP mod and see if the problem goes away. If the bike was ok before dont mess with it.
