Hi, I had an 2006 CRF 250X that I jet with the JD kit, Red needle, 158/42, AP mode, open air box and an Arrow muffler and it was a very nice bike, with lot of low and middle power, not very high rpm but it was ok for technical and slow trails that was I do.
Right now I sold the "old" 2006 and bought a new 2011 (2009) 250X and tried to jet it myself, because I spent all my money on the bike and it's a "little" expensive to buy a new JD kit from the States (I live in Portugal, you know).
So, I opened the airbox, maybe a little too much, because I didn't remember what I have done 5 years ago, so I opened all the upper section of the box (I don't know if this is a problem of too much air) and as I have an NCYS needle and saw that many guys use it, I put this needle in, clip 4, and as this 2009 bike has already the 42 slow jet I only change the stock 132 main jet with a 155 one and the pilot screw passed from 1 3/4 out to 2 1/4 out. No AP mode required in this new 2009 bike, I have an Arrow header that has a little larger diameter than stock and use a new Leovince X3 muffler and didn't do the pink wire and I ride sea level to 2000 ft.
Right now what I state: the bike revs very high, it never ends with a very linear, not explosive power and even in 5th gear the bike cuts the ignition off at more than 12.000 rpm (I have an rpm meter) but it has no soul as my old 2006. At low and middle power it's difficult to get the front wheel of the ground.
This is the contrary of what I want, I don't need to do very high rpm but need low power to raise the front to pass roots, rocks and so.
I read in some forum (didn't remember which) that this new 2009 motor has a different top head more like the 250R and maybe because of that I can't find the low end as I expected, but as also the carburetor isn't the same of the old bike, now it's a FCR14B and the stock needle now is the NKKT maybe the NCYS needle and the 2 1/4 out isn't the correct jetting for this 2009 CRF 250X.
Any advice on this matter?
Thanks in advance from this side of the Atlantic.
Best regards.
Miguel Cunha
