Jet needles
Posted: Mon Oct 11, 2010 8:57 am
by TRD
I´m having a needle issue. Modified CRF250R 2009 engine and I need to change different needle. Is there any translator what Honda needle codes mean?
Example stock needle is NNTU. What are specs? Keihin uses own codes which seems to be different. Anyone can help? I can order from honda too needles but catalog only inform their codes.
Cheers,
Timo
Posted: Mon Oct 11, 2010 12:42 pm
by n2stackin
ok, maybe this will help. page 127 talks about standard jetting and altitude. page 128 talks about a modified engine.
http://www.hondamc.com/upload/Download/CRF250R9%20Instruktionsbok.pdf
Posted: Mon Oct 11, 2010 5:15 pm
I'd highly recommend getting the JD Jetting Kit. It includes two needles that have been custom tapered specifically for the CRF250R. Here's a link:
http://www.crfsonly.com/catalog/product ... ts_id/2657
Posted: Tue Oct 12, 2010 4:20 am
by TRD
Thanks but those wont really help me. I have Honda manual and it tells NNTU is right needle but it´s not.
I have right jetting allready so I don´t want to spend money for JD Jetting Kit because it´s not sure that it will work.
I know what I need when I see information about NNTU needle but it´s difficult to measure needle accurately.
I drive enduro and my 2009 CRF250R has lower compression ratio then stock and different camshaft timing. Engine is milder and not so much snap on it then stock. Power comes up in lower rpm. So that´s why the needle problem.
- Timo
Posted: Tue Oct 12, 2010 6:30 am
by n2stackin
Email or call the shogun, James Dean himself. He is a nice guy and can probably help you without trying to sell you something. If you can't find what you need by checking the forum, googling it, or calling your local dealer, that is my suggestion.
Posted: Tue Oct 12, 2010 7:16 am
OK Timo,
here's how the lettering system works. Let's compare two commonly used needles in the CRF's, the NCVS and the NCVU.
The NCVU is leaner than the NCVS.
The lettering system works like this:
After the N, the first letter is the taper. "C" so they are both the same taper.
The second letter is the clip postion relative to the top portion of the taper. They are both V. They get leaner as you go up thru the alphabet towards Z.
The third letter is the needle straight diameter.The S is richer than the U. They also get leaner as you go up thru the alphabet towards Z.
Hope that helps.
Posted: Tue Oct 12, 2010 7:22 am
by n2stackin
or... AS can answer.
Posted: Wed Oct 13, 2010 12:33 pm
by TRD
All I ever wanted to know
Thanks a lot all of you!
- Timo
Posted: Wed Oct 13, 2010 1:10 pm
by TRD
Ok no I´m buying NNTS needle place of NNTU.
If we compare NNTS needle and AS mensioned NCVS needle result is.
NNTS taper angle is bigger than NCVS
NNTS length diameter is smaller than NCVS
NNTS needle straight diameter is the same than NCVS
Does all those Honda CRF needles fit apart? If I rememer right older CRF´s have little bit different FCR Keihin on it.
Posted: Wed Oct 13, 2010 2:03 pm
The older needles will fit the newer carbs without issue.
The newer needles will need the new holder assy to fit the older carbs.
Since you have an 09, any needle will fit without issue.
Posted: Wed Oct 13, 2010 9:29 pm
by TRD
Cheers! I believe right setup will find now.
- Timo
