Need some advice!! CRF450X JD Jet kit
  • shawnbo
    by shawnbo » Thu Apr 08, 2010 9:40 am
    Hey guys,
    I need some clarification and/or advice.
    I have a 2005 CRF450X. Just got a JD kit and installed it. I have a few questions.
    I live in Denver CO. I ride at 5000-12000ft - Per the instructions I've put the red needle in, 3rd clip position and I used the #160 main.
    I have the following mods:
    1. FMF Titanium Powerbomb Exhaust with FMF Megabomb header
    2. Full airbox mod, top and side - Twin air filter
    3. Backfire screen removed
    4. I did the AP mod as well
    5. Pink wire isn't done - should I?
    6. 45 Main, stock
    7. Stock leak
    As I was reading the instructions I saw the section that talked about racing mods and to use the #170 main. I'm assuming that is for sea level. So if I'm running a #160 should I run a #165 with all my mods?
    Anyone riding at this altitude with similar mods? I didn't find anything in the jetting section.
    Thanks for the help.
    450xdirt
    by 450xdirt » Thu Apr 08, 2010 11:41 am
    Most of my riding is at 5000-10,000 ft I use the following and it works really well:
    165 main
    JD needle 4th from top
    45 pilot
    1 1/2 turn out on the fuel screw.
    You don't really need to do the pink wire mod until you put an R cam in or hot cams.
  • shawnbo
    by shawnbo » Thu Apr 08, 2010 12:20 pm
    What mods do you have?
    450xdirt
    by 450xdirt » Thu Apr 08, 2010 12:25 pm
    check out my garage...
    Open air box
    Ti4 pipe
    FMF power bomb
    Twin air power flow
    boysen QS2
  • shawnbo
    High Altitude riders with MODS l@@K here!!!!
    by shawnbo » Thu Apr 08, 2010 5:39 pm
    Got it. Runs perfect.
    Year: 2005
    Model: CRF450X
    Elevation: 5000ft-13000ft
    Temperature Range: 20-100 degreees
    Smog (AIS): N/A
    Airbox Modified Top: YES
    Airbox Modified Sides: YES
    Backfire Screen: REMOVED
    Air Filter: TwinAir
    Pilot Jet: 45 Stock
    Main Jet: 165
    Needle: JD RED
    Needle Clip Position: 4th
    Fuel Screw Type: Storm
    Fuel Screw Setting: 1 1/2 turns
    AP Modified: O-Ring
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: FMF PowerBomb TI with FMF Megabomb Header
    Exhaust Modified: Full
    Pink Wire Modified: NO
    450xdirt
    by 450xdirt » Thu Apr 08, 2010 5:44 pm
    Awesome! Glad to hear it. Have fun twistn' it :twisted:
    Don't forget to keep an eye on your plug to see exactly how she's running.
