Jetting for Port & Polish?
    motosicko
    by motosicko » Mon Mar 01, 2010 9:56 am
    Just had my 08 450R ported,and new top end, and got it out Sat. for a quick break-in.
    It runs good and strong, but was getting a little back-fire on decel. So I put a richer (178 from 175) main jet in and it helped a little. Question is: Does a port/polish generally require richer jetting? The guy that ported it told me he though the jetting should remain the same. I'm going to check the plug tonight for a true indication, just thought someone with port experience could shed a little knowledge. AS?? or any one else??
    My thoughts are that if you increase the flow without adding a little more fuel, that it will be drawing more air, in turn leaning the mixture. :?: :?: :?:
    "There are old racers
    and there are bold racers,
    by Asmith » Mon Mar 01, 2010 10:07 am
    You are correct if the porting is done well and you haven't sacrificed velocity for volume.
    The decel pop is a pilot jet issue as the main is closed on decel.
    What pilot are you running?? 45?
    motosicko
    by motosicko » Mon Mar 01, 2010 10:20 am
    Yep 45. Needle clip 2nd down. Temp was a bit cool at 45, so I richened up the fuel screw a bit. it didn't pop very much after the main jet change, only on the stand while I blipped the throttle, and maybe once on the track, minor, but it's been so perfect in the past.
    Thanks for verifying that I should need the adjustment.
    woodsman
    by woodsman » Mon Mar 01, 2010 8:01 pm
    I went 1/8 - 1/4 turn in on the fuel screw and that seemed to fix my backfiring issues. :?
    Currently, 05 450X
