CRF2008 x Jetting
  • My CRF
    CRF2008 x Jetting
    by My CRF » Fri Jan 15, 2010 4:05 am
    I have always had a boggy mid throttle
    Opened carb and discovered
    Main Jet 132
    Pilot 42
    Leak 68
    Needle Clip 3
    132??? is that correct?
  • mxersraz
    by mxersraz » Fri Jan 15, 2010 7:09 am
    The bike needs to be rejettet and breathe more from stock.
    First of all you have open up/cut the airbox,
    Remove the air filter backfire screen
    Drill the exhaust's baffle or change to an aftermarket can.
    Then for jetting:
    165-170 main
    stock or 45 pilot
    JD red needle or NCVS needle on 4# from top.
    All theese depend to your elevation and temperture though.
    The best way to go is buy the JD kit for the x.
    It has everything with perfect directions.
    Back to the nature!! 450x
  • My CRF
    by My CRF » Mon Jan 18, 2010 5:25 pm
    I will give it a crack, thanks for the advice
