power up kit for a 230
    lovestoride
    by lovestoride » Sun Jun 07, 2009 6:22 pm
    which main jet should i use for riding around 3000'? 132 or 135? and ive heard i need to open up the air box but how much?
    thanks
    by Asmith » Sun Jun 07, 2009 6:53 pm
    132 main jet. 4th clip on the needle.
    Cut at least the top of the airbox off.
    amaviper
    by amaviper » Sun Jun 07, 2009 7:35 pm
    Most owners just pull the "snorkle" and rubber gasket from the top. No cutting.
    lovestoride
    by lovestoride » Sun Jun 07, 2009 9:56 pm
    4th clip counting from which end?
    by Asmith » Sun Jun 07, 2009 10:24 pm
    lovestoride wrote:4th clip counting from which end?
    The top, Flat or Blunt end
    lovestoride
    by lovestoride » Mon Jun 08, 2009 6:38 pm
    alright thanks
  • adnoh
    by adnoh » Tue Jul 28, 2009 5:03 pm
    If I have a never ridden '08 230, I want remove the intake snorkel and muffler baffle, then install a power up kit. Can I just replace the main jet and leave the needle alone? Or do I have to replace everything that is sent in the kit?
    lovestoride
    by lovestoride » Wed Jul 29, 2009 12:03 am
    i put in all the parts they gave me in the kit and it runs perfect and is amazingly better. i dont see any reason not to. once you have the carb all opened up the other parts only take a minute to switch out.
    by [email protected] » Wed Jul 29, 2009 2:55 am
    Good thinking. You do get a little more power, but the larger benefit is cooler running, quicker starting and smooth top to bottom throttle response. Easier to ride, not more challenging.
    It happens quite a bit where folks will seek help, we or the manufacturer will tell them all that's required then the new owner resists doing all of the job for some reason. Then they don't get all the benefits.
    Glad you like it, it's quite a difference.
    Now you should install a 14 tooth countershaft sprocket.
    You'll have a first gear actually good for something (it sure isn't stock), you'll lose no climbing ability and it will pick up appx 10 mph top end speed.
    Many will say they don't need that. Most will find eventually they do. :lol: Doug
    lovestoride
    by lovestoride » Wed Jul 29, 2009 5:50 pm
    i've actually heard i should put the 14 tooth sprocket in and am thinking i will. is the stock one 13?
    by [email protected] » Thu Jul 30, 2009 8:08 am
    It is.
    230 riders who ride primarily wide open spaces even do well with a 15. If you ride trails/woods,etc. that can get tight a 14 will work super.Doug
  • adnoh
    Suggestions on ...
    by adnoh » Wed Sep 16, 2009 6:14 am
    where to buy 14 tooth sprocket and what brand should I buy?
    by [email protected] » Thu Sep 17, 2009 7:03 am
    Most any brand of countershaft sprocket is fine. They are steel and there's not the huge difference in quality that there is in rear sprockets.
    I think that we have one here on crfsonly, Sprocket Specialists has one for sure. Doug
