Raised clip on bike and throttle not working?
  • DocCRF-X250
    by DocCRF-X250 » Sun May 17, 2009 7:20 pm
    I raised the clip on my sons crf 70 and after doing it I put it back together and as soon as i screw the throttle cable into the top of the carb it seems to stop or pinch the throttle cable and the throttle does not work? Is there a certain way or trick to putting the thrttle cable with clip back in? Any info would be awesome!!
    '04 250 X-- Air box open, JD Jet Kit, FMF Ti Powercore exhaust, Twin-Air Power Flo Air filter, AP Mod
    '07 CRF 70 (sons)--Pod air filter, opened exhaust and re-jetted
  • jjrace
    by jjrace » Wed May 20, 2009 8:30 am
    did you put the slide in backwards?
    #861
    '05 crf450r
  • DocCRF-X250
    by DocCRF-X250 » Wed May 20, 2009 1:07 pm
    I got it figured out, I had to turn the barrel 180 degrees. Once I did that it went in all the way and all is good now. Thanks
  • jjrace
    by jjrace » Thu May 21, 2009 8:10 pm
    that is what is called the throttle slide or slide for short
    #861
    '05 crf450r
  • DocCRF-X250
    by DocCRF-X250 » Fri May 22, 2009 8:36 am
    thanks for the info and the help!!
