Is it normal for gas to come out of the overflow tube?
  • corey_lax
    by corey_lax » Tue Jun 10, 2008 5:50 pm
    i'll start off with the relative specs on my bike.
    I have:
    cut the top of airbox
    removed the backfire screen
    pink wire stock.
    removed exhaust baffle
    O ring mod
    42 pilot jet
    fuel screw out 1 3/4
    165 main jet(had 160 on but it would stall after quick snap of the throttle from idle)
    jd red needle on 5th clip from top
    ride from 0 to 3500ft
    temperatures from 40 to 100 degrees
    now... I went for a quick ride around the block with the 160 main jet got back and there was some drops of fuel coming out of the over flow tube. I switched to a 165 main, rode around the block. The bike idles so smooth and rides unreal but when i get back... same old drops of gas coming out of the overflow tube. Is this a normal thing to happen with jetting? Is it from me ripping then shutting it off pretty quick? or should i change something in my jetting?
    Re: Is it normal for gas to come out of the overflow tube?
    by 124 » Wed Jun 11, 2008 5:45 am
    corey_lax wrote:i'll start off with the relative specs on my bike.
    I have:
    pink wire stock.
    O ring mod
    42 pilot jet
    Which overflow tube is it coming out of?
  • corey_lax
    by corey_lax » Wed Jun 11, 2008 6:37 am
    one that comes out right at the float bowl plug...
    by 124 » Wed Jun 11, 2008 8:20 am
    corey_lax wrote:one that comes out right at the float bowl plug...
    Then this is indicative of your float level too high. Possibles:
    --Your fuel screw o-ring is leaking air past it.
    --You have dirt or foreign debris keeping the main needle and seat from sealing off correctly.
    --You changed your float level by bending the tab on the float itself.
    --The float bowl gasket is leaking air past it.
    Somehow the float level is too high. Allowing air into the bowl via a non-designed pathway, dirty or bad needle/seat, or float adjustment is incorrect...
    mikey526
    by mikey526 » Wed Jun 11, 2008 9:35 am
    Or the drain screw just might not be tightened all the way.. :D I've done that before... :shock: :D
    by 124 » Wed Jun 11, 2008 10:05 am
    or that! :roll: :D
  • corey_lax
    by corey_lax » Wed Jun 11, 2008 12:59 pm
    could it just be the air trapped in the float working its way out? i just had the float plug out to change the main jet and then went for a less than two minute ride. think its just because the air that is inside the float hasnt worked itself out yet? im a carb rookie. i really doubt that theres dirt anywhere tho... i cleaned everything out before taking the carb apart. I might need to tighten the float plug though becuase i changed this out very quickly and might not have tightened it down enough. plus i couldnt get my 17mm socket on properly because the bike was completly put together and not much room.
    thanks for all your help
    corey
