05 450x more jetting
Posted: Sun Mar 02, 2008 5:33 pm
The way i originally set the bike up was a 158main, 55 leak and 48 pilot, ran great then began the popping on the last ride.
Here's what i've done since, and the problem! JD kit red needle 4th clip, 165 main, 45 pilot, 70 leak. Major popping on the deceleration side. Also tried a 170 main, 48 pilot, and 55 leak. Same problem's. Also the bike has a whitebrothers' pipe, opened up air box.
Any suggestions? Also the throttle/floating valve the little rubber piece between the too seems a little shrunk!
