jetting ? 06 250x the boggggg
    kenjohn1975
    by kenjohn1975 » Thu Feb 21, 2008 6:11 pm
    06 250x still have a bog cruzing at trail speed hit gas for a puddle im wet
    this is what i have done so far, open air box, 16204-men-671 needle,3rd clip from top,152 main,70 leak,pilot stock,quick shot2,un corked pipe,fuel screw 2 turns out.& and pink wire mod
    i ride in temp av around 65 or so 500 to 4000ft.
    any seggetion please.
  • redrooster65
    by redrooster65 » Thu Feb 21, 2008 7:11 pm
    Defiantly go with the 42 pilot, also seams a little light on the main. A 165 seams to be the ticket with the sea level guys.
  • jayc250x
    Re: jetting ? 06 250x the boggggg
    by jayc250x » Tue Apr 01, 2008 12:07 pm
    kenjohn1975 wrote:06 250x still have a bog cruzing at trail speed hit gas for a puddle im wet
    Everything you've done might help top end, but you've done nothing to correct the off-idle bog. You want to bump up your pilot to a 42, then tune the fuel screw for best bog-free off-idle response (0 to 1/4 throttle snap). Going to a 70 leak jet makes the bog worse - stock is a 50 or 55 - go back.
    I don't know what it typical on that needle, but your main is probably OK, though it might still be a hair lean too.
    FYI: I'm currently running a 45 pilot at 2 turns, 155 main (which is still too lean BTW), and stock needle at position #5 with a 10% ethanol mix. You're settings with normal gas would be a tad leaner. I have a CCC opened airbox and no other mods. My bike has instantaneous throttle response across the board, though falls a little flat at WFO due to the lean 155 main - no trace of a bog anywhere.
    JayC
