Not another jetting question?
    Malindor
    by Malindor » Fri Feb 01, 2008 9:18 am
    I will be ordering the JD Jet Kit as well as the White Brothers E2 slip-on for my 07 450X. I have only performed the smog block off mod to date. I am going to open the top of the air box as well as installing the Twin Air Filter that you are all so fond of. I will also be doing the Crank Case Breather mod. So my question to the Honda Bike Gurus is, which pilot and main jet should I use for riding in the Michigan area...
    Re: Not another jetting question?
    by Asmith » Fri Feb 01, 2008 2:47 pm
    Malindor wrote:I will be ordering the JD Jet Kit as well as the White Brothers E2 slip-on for my 07 450X. I have only performed the smog block off mod to date. I am going to open the top of the air box as well as installing the Twin Air Filter that you are all so fond of. I will also be doing the Crank Case Breather mod. So my question to the Honda Bike Gurus is, which pilot and main jet should I use for riding in the Michigan area...
    The JD kit will come with all the charts you will need to properly set it up.
    Most likely you will use the stock 45 pilot and the 170 main along with the JD red needle on the 4th clip.
    Malindor
    by Malindor » Mon Feb 04, 2008 7:07 am
    thanks bro...
