rob_wiggins wrote:what the hell is jettin? I have been reading all the threads and as far as i can tell it is the way your bike breaths, which is important at altitude?
In a nutshell, it's the combination of the jets (orifices thru which the fuel passes)
the needle shape, and the position of the clip on the needle.
It's a delicate balance trying to provide an ideal mixture of air to fuel.
Gasoline likes to burn at a ratio of 14.7:1 ( this is known as the Stoichiometric air-fuel ratio ).
More gasoline lowers the ratio, less gasoline raises the ratio.
Above 17:1 it is too lean to burn effectively, below 14:1 it is too rich to burn effectively.
Since each part controls a different part of the throttle,
they must be adjusted separately to work in harmony with each other.
The pilot jet controls fuel from idle to 1/4 throttle.
The needle jet controls fuel from 1/4 throttle to 3/4 throttle.
The main jet controls fuel from 1/2 throttle to WFO.
The AP ( Accelerator Pump ) shoots a small shot of fuel during rapid twisting of the throttle to aid in the increase of RPMs in a smooth manner.
Too much will cause bog and too little causes bog.
That was a big nutshell...
